Activity › Forums › Maxon Cinema 4D › Expresso – Countdown Timer
Posted by David Biederbeck on August 18, 2011 at 9:35 pmAny suggestions on how to rig a key-frameless countdown?
Keith Anderson replied 15 years ago 4 Members · 5 Replies -
Brian Jones
August 19, 2011 at 12:08 amFeed a constant – Time into a text spline’s or MoText’s text input in xpresso
Adam Trachtenberg
August 19, 2011 at 3:27 amNo big deal — it’s quite easy. I used an extruded text spline in my case. You’ll just have to play with rangemapper values, mainly. Here’s an image of the Xpresso setup:
Be sure to set the nodes to integer where possible.
Keith Anderson
August 23, 2011 at 7:12 pmThanks for that Adam. I am on 10.2 and the setup from your image works great!
I am trying to get it to countdown in seconds.
everything works fine, but is there a settin to make the 9 – 0 be 2 digits ie 09, 08, 07, 06, 05, 04, 03, 02, 01, 00 instead of 9,8,7,6,5,4,3,2,1,0
