Activity Forums Adobe After Effects Expressions Expressions to control particles
  • Expressions to control particles
    Posted by Øystein Dahl godø on September 10, 2012 at 12:14 pm
    I have a “jungle” scene, where I need to have an easy way of animating small insects/bugs flying around as the camera moves. I was thinking of making each insect/bug as a particle, and I need an expression to control the flow of the particles. This way I don’t have to animate all the bugs seperately, and hopefulle save much time.
    Any suggestions on how to best achieve this effect? Sample expression would be great too.
    Regards.
    Kevin Camp replied 13 years, 11 months ago 2 Members · 3 Replies
  • Kevin Camp
    September 10, 2012 at 3:31 pm
    you would need to describe how you want the particle to behave. you should also include any third-party particles effects that you may have (like trapcode’s particular, etc.).
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Øystein Dahl Godø Create COW Profile Image
    Øystein Dahl godø
    September 11, 2012 at 5:53 pm
    Hi Kevin.
    I want the particles to move around in random (like the bugs/flies moves in real life).
    I primarly want to use Trapcode Particular. But if you have suggestions on other plug-ins that would ease the effect, you are welcome to suggest that as well.
    Regards,
    Øystein Godø
  • Kevin Camp
    September 11, 2012 at 7:29 pm
    particular is a good plugin for this and it can do this without expressions.
    in the physics>air>turbulence settings increase the ‘affect position’ value. this will cause the particles to move randomly after birth.
    you can fine tune the random movement with the other settings in the turbulence field.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
