Activity Forums Adobe After Effects Expressions Expressions that change layer-in point.
  • Expressions that change layer-in point.
    Posted by Wouter Bruneel on January 29, 2010 at 3:21 pm
    Hello everyone,
    I’ve been putting together a tunnel by having a section of it travel a path in a precomp and then in the main comp time-remapping that pre-comp along the path. (a lot of layers with a time-remap expression based on the index of the layer) This gives me a lot of layers, about 400. On my machine rendering this out takes about 160 hours. So i want to cut that time by just rendering the layers I see. I should be able to determine the layer in-point based on the time remapping value but i have no idea how to implement this. Any ideas out there?
    Another question. If i can’t manipulate the in-point, will animating the opacity to zero cut back to the render time? Does after effects skip layers with an opacity of zero?
    Thanks for the help,
    Wouter
    Wouter Bruneel replied 16 years, 7 months ago 2 Members · 4 Replies
  • Dan Ebberts
    January 29, 2010 at 5:16 pm
    You can’t change in points with an expression. I’m not 100% sure, but I’d guess that layers at 0% opacity still render (someone else please jump in here if I’m wrong). Probably what you need is a script that will go in and trim the in points for you.
    Dan
  • Wouter Bruneel
    January 30, 2010 at 4:07 pm
    Thanks for the reply, Dan.
    Where would I put an expression that trims my in points? Surely not in a transform attribute like position. If necessary I can probably skip the expression, and roughly trim the layers by hand.
    Thanks again,
    Wouter
  • Dan Ebberts
    January 30, 2010 at 5:08 pm
    I’m sorry if I didn’t explain it clearly. You can’t do it with an expression. It would take a script.
    Dan
  • Wouter Bruneel
    January 30, 2010 at 9:04 pm
    ok. Sorry, i read over “script” in your initial reply.
    Thanks again,
    Wouter
