Activity Forums Adobe After Effects Expressions expressions switches off randomly / bug?
  • expressions switches off randomly / bug?
    Posted by Sergei Sokolov on June 19, 2009 at 9:09 pm
    Hi all,
    Same bug as was asked about in this forum earlier in 2007 and 2008:
    some expressions randomly switches themselves off – i.e. equal sign goess off, no error messages, no warnings. I just see that the chain brakes at some point. As soon as I switch them back on, some of the other ones go off.
    Same situation as was described: many layer copies, expressions refer to other layers / previous time, motion blur. After Effects CS3.
    Expression example:
    Rotaion X: thisComp.layer(thisLayer.index + 1).rotationX.valueAtTime(time – 1/25)
    There are about 30 layers logically chained one after another, forming a trail as the master layer rotates by keyframes.
    Kind regards,
    Sergei Sokolov
    Here’s the project file zipped:
    https://depositfiles.com/files/3ramxnwkz(8kb zip)
    Is there any limit of number of dependencies within a single comp?
    Is there a “best practice” of how to handle such recursive expressions?
    What to do with “time before times” which is referred to at frame 0 and by motion blur?
    Sergei Sokolov replied 17 years, 3 months ago 2 Members · 3 Replies
  • Dan Ebberts
    June 19, 2009 at 10:19 pm
    I’d use an expression like this:
    delay = 1/25;
    M = thisComp.layer(“c1 master”);
    M.rotationX.valueAtTime(time – (M.index – index)*delay)
    thisComp.layer(thisLayer.index + 1).rotationX.valueAtTime(time-1/25)
    It assumes that “C1 master” is lower in the layer stack than the layers with the expression. Pretty cool project, BTW.
    Dan
  • Dan Ebberts
    June 20, 2009 at 3:44 pm
    Sorry. Clearly the last line of the expression posted above doesn’t belong there. It should look like this:
    delay = 1/25;
    Dan
  • Sergei Sokolov
    June 21, 2009 at 9:18 am
    Thank You, Dan!
    I got the idea: let each layer refer to the master layer, rather than to a neighbor.
    Now it works fine.
    My expression for Y rotation is:
    thisComp.layer(“c1 master”).rotationY.valueAtTime(time-(thisComp.numLayers – index + 1)/25)
    Same for X rotation.
    And the shape layer size expression is
    k = (thisComp.numLayers – thisLayer.index+1)*20;
    [k, k];
    Inititally there are two layers: “c1 master” with keyframes, and the “c2” with these exp. Then just duplicate the “c2” 20-30 times to get extra circles.
    Let me credit Satya Meka at ae.tutsplus and Mark Coleran for the concept of the effect.
    Kind regards,
    Sergei
