Activity › Forums › Adobe After Effects Expressions › Expressions stop functioning when key-framed
  • Expressions stop functioning when key-framed
    Posted by Daniel Gies on May 25, 2010 at 4:42 pm
    Is there a way to reference an object in a parent composition without referring to the parent composition by name? I would like to have some control objects that control objects within a composition without me having to re-reference the parent comp name for every shot.
    Any thoughts.
    Thanks.
    dan
    Daniel Gies replied 16 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 25, 2010 at 5:38 pm
    Since a comp can appear in any number of “parent” comps, there’s no way for an expression to get there, except by name. In some cases you can work around it with a clever naming scheme where the expression can figure out the name of the parent comp based on something it does have access to (possibly the name of the comp containing the expression). I’m not sure if that method would help in your case though.
    Dan
  • Daniel Gies
    May 25, 2010 at 6:12 pm
    That is what I figured. No Worries. Thank you for your help!
    dan
