Activity Forums Adobe After Effects Expressions Expressions randomly turn themselves off?
  • Expressions randomly turn themselves off?
    Posted by Charlotte Caetano on October 29, 2008 at 2:39 pm
    Hi there,
    I have created a composition in AE CS3 which contains many layers that have the same expression (as featured in maltaannons CG snake tutorial) It all works perfectly… the layers follow each other as expected etc…. and then I simply click or look at another layer or file within the same comp. and a handful of the aforementioned layers switch their expressions off randomly meaning that I have to manually detect which ones have done this and turn them back on… then, all is fine and works well … until the same thing happens again…
    Does anyone else have this problem?
    If so, is it simply an annoying bug that I have to accept, or is there a fix for this?
    Many thanks
    Charlotte
    Charlotte Caetano replied 17 years, 10 months ago 2 Members · 4 Replies
  • Dan Ebberts
    October 29, 2008 at 5:02 pm
    Really hard to say without seeing the project (or at least the error message and the text of the broken expression), but there are a couple of things I know of that seeminly break expressions at random. If motion blur is turned on, it can cause an expression to execute before frame 0, where everything that the expression references may not be defined, and having the graph editor turned on can do the same thing because it draws a little piece of its graph to the left of time 0.
    Dan
  • Charlotte Caetano
    October 29, 2008 at 8:41 pm
    Hi Dan,
    Thank you for your prompt reply.
    I turned off all the options and switches I could think of (for the moment) though the expressions do still keep randomly turning themselves off. There are no error messages, it just suddenly occurs.
    I have wondered if the problem cannot be fixed, is there a shortcut key to enable and disable all expressions on selected layers at once? As opposed to having to twirl down the postion properties of each layer?
    Failing that, is there a way to create a further expression in the compostition (perhaps linked to a null with a checkbox) that will achieve the above function?
    I hope this makes sense,
    Thank you for your help
    Charlotte
  • Dan Ebberts
    October 30, 2008 at 3:22 pm
    I’ve never seen an expression turn itself off without an error message.
    In any case, the only thing I can think of would be a script that would go through the project looking at each property, checking for expressions that are disabled. I don’t have a script like that, but someone may have one.
    Dan
  • Charlotte Caetano
    October 30, 2008 at 7:05 pm
    Hi Dan
    Okidoke I will have a look around. Thank you for your efforts and advice.
    All the best,
    Charlotte
