Activity Forums Adobe After Effects Expressions Expressions question: creating control that displays a variable’s value
  • Expressions question: creating control that displays a variable’s value
    Posted by Nicholas White on May 6, 2005 at 8:19 am
    Hello,
    For testing purposes I want to see what the value of a variable is that I’ve created in an expression.
    For the position of layer 1 I’ve added the following expression:
    x = random(0,1)*100;
    position = [300+x, 200+x]
    What I’m trying to do is add a slider box controller to the position property which will show me what the value of x is at any time in the timeline. It’s easy to find the position value, but when I try to add something like:
    thisLayer.position.x
    I get “Undefined value used in expression. Could be an out of range array subscript?”
    I’m able to do this when writing scripts by using the alert() method to pop up little boxes with the value of x in it…can I do something similar with expressions?
    Nick
    Dan Ebberts replied 21 years, 3 months ago 3 Members · 2 Replies
  • Mylenium
    May 6, 2005 at 9:37 am
    Nope, not really. Actually you would need to work differently and generate your random values or whatever separately on another layer. Those can then be linked to text layers, sliders etc. for visual feedback. Having an alert() in expressions would be kinda counter-productive, don’t you think?
    Mylenium
    [Pour Myl
  • Dan Ebberts
    May 6, 2005 at 1:14 pm
    If you wanted to show the x position value with a slider applied to the same layer, you could use:
    position[0]
    If you wanted to display it with a text layer you’d use this expression for the source text:
    thisComp.layer(“your layer”).position[0]
    Dan
