Activity Forums Adobe After Effects Expressions Expressions – Question about actual and relative path
  • Expressions – Question about actual and relative path
    Posted by Anja Riehl on January 20, 2017 at 12:08 pm
    Hello there,
    I am using the expression below, but somehow the way I did it, isn´t working for me.
    Is there a way to use relative paths?
    Can anyone help? This would make my day 🙂
    comp("SCENES 1-10").layer("CAM ctrl").transform.yRotation;
    C = comp("SCENES 1-10");
    L = C.layer("POPUP PAGE 3");
    C.layer("CAM ctrl").transform.yRotation.valueAtTime(time+L.startTime)
    Anja Riehl replied 9 years, 7 months ago 2 Members · 8 Replies
  • 8 Replies
  • Dan Ebberts
    January 20, 2017 at 6:37 pm
    What is it you’re trying to do? The way you have it written, it doesn’t appear that the first line will do anything.
    Dan
  • Anja Riehl
    January 22, 2017 at 4:10 pm
    Hello, my CAM ctrl layer is connected to the CAM ctrl layer in the main composition. That is what the line is for. What I’ll need is my script with a relative path.
  • Dan Ebberts
    January 22, 2017 at 6:21 pm
    Sorry, I don’t know what you mean by “relative path”.
    Dan
  • Anja Riehl
    January 22, 2017 at 6:43 pm
    Let me explain…
    At the moment I am using an expression like that:
    L = C.layer(“POPUP PAGE 3”)
    With an actual path “POPUP PAGE 3″…is there a way to generalize this?
    The “POPUP PAGE 3” composition is part of the Main Composition, so a level above.
    Do you need more information?
    Thank you.
    Anja
  • Dan Ebberts
    January 22, 2017 at 6:50 pm
    You could do this:
    L = C.layer(thisComp.name)
    but you can only reference the main comp by name, if that’s what you’re asking.
    Dan
  • Anja Riehl
    January 22, 2017 at 7:42 pm
    Ok, this is the expression that I am using. (below)..so I can only change the general path for the second line? Can I work with “_parent”?
    C = comp(“SCENES 1-10”);
    L = C.layer(“POPUP PAGE 3”);
    C.layer(“CAM ctrl”).transform.yRotation.valueAtTime(time+L.startTime)
    Sorry, for sounding so weird. I am an absolute beginner when it comes to scripting with AE.
    It’s such an amazing and complex program.
    Thank you so much for your time and help.
    Anja
  • Dan Ebberts
    January 22, 2017 at 8:24 pm
    There is no way to access the “parent” comp, except by name.
    That’s by design, because a precomp only renders once–you can’t have a precomp render differently based on what parent crop you drop it into.
    Dan
  • Anja Riehl
    January 23, 2017 at 12:07 am
    Ok, Thank you so much for your help Dan.
    Anja
