Activity Forums Adobe After Effects Expressions Expressions question
  • Expressions question
    Posted by Joshua Stanley on August 23, 2005 at 3:38 pm
    I asked this question below, but it was kind of buried at the end of a question so I didnt get any response.
    I was messing with the code that George Polevoy had posted to create a spring between objects(see below).
    When I use it I keep getting the warning “expression must be of dimension 2, not 1.
    I realize this is because it is only getting input for the x parameter and it is looking for the x,y but I can’t tell by looking at the code where the parameter is being declared.
    Can any one help??
    // AE expression by George Polevoy
    // http://www.creativecow.net
    // attaches an object to a “Controller” object with a “spring”
    // You need another “Controller” which will drive animation of this one
    // parameters
    conserveMotion = 0.95; // valid range: 0.5 to 0.995
    springResistance = 10; // positive values
    prerollTime = 2; // value in seconds. greater values give more precise result
    fps = 1.0 / this_comp.frame_duration;
    if ( prerollTime > time ) prerollTime = time;
    dt = this_comp.frame_duration;
    frame = time * fps;
    integrationTime = time – prerollTime;
    s = [0,0];
    p = this_comp.layer(“Controller”).position.value_at_time( integrationTime );
    i = frame – prerollTime * fps;
    for (; i < frame; i++, integrationTime += dt ) { c = this_comp.layer("Controller").position.value_at_time( integrationTime ); d = c - p; s = s + d * springResistance; s = s * conserveMotion; p = p + s * dt; } p; Josh
    Activity
    Dan Ebberts
    replied 21 years, 1 month ago
    2 Members · 3 Replies
  • Dan Ebberts
    August 23, 2005 at 5:34 pm
    The only thing I can think of is that you’re running AE 5.0, in which case you would need to use the funky vector math stuff instead of +,-,*,/ for the vector operations.
    Dan
  • Joshua Stanley
    August 23, 2005 at 6:47 pm
    Dan-
    I’m working on AE 6.0 production on a mac. Maybe Ill try this tonight at home on a pc 6.5.
    thanks
    Josh
  • Dan Ebberts
    August 23, 2005 at 9:15 pm
    I’m stumped. I just copied and pasted the expression from your post into AE 6 and it works fine. You are applying it to the position property, right?
    Dan
