  • Posted by Lior on June 10, 2005 at 8:19 am
    When i’m using 3D Layer i want to create Exprsn’ that control only on one of the axis. for Exmp’:
    I took from one layer the position factors and add only for the Z axis 10 pixels.
    the result i got is not what i wanted.
    i want one layer to be Far from each other only in the Z axis using the Exprsn’ tool.
    Help Anyone ?
    Thank you.
    Filip Vandueren replied 21 years, 3 months ago 2 Members · 1 Reply
  • Filip Vandueren
    June 10, 2005 at 8:53 am
    do your calculation for example:
    z=Math.cos(time);
    then conclude your expression with this
    [value[0],value[1],z]
    this will take the x and y coordinates from value (=the properties value before expressions) and use the variable z as the third coordinate.
