Activity › Forums › Zaxwerks › Expressions problems in 3D
  • Expressions problems in 3D
    Posted by Christopher Rotter on June 27, 2009 at 1:47 am
    I’m hoping someone could help me, I have a invigorator object and I want to apply a loop expression as well as a delay expression so that the layer loops and the other invigorator layers do the same as in loop but also delay. The problem I run into is that I don’t know how to apply this because I’m animating with three axis and when I apply the expression of loopOut to all three axis the loopOut expression doesn’t work.
    Christopher Rotter replied 17 years, 3 months ago 2 Members · 2 Replies
  • Edward Wu
    June 29, 2009 at 9:52 pm
    Hi Chris,
    I’m not well versed in writing expressions, but if you’d like you can send me the project file and I can take a look at what you are trying to set up, and also see if there are any workarounds to what you are trying to achieve.
    My e-mail address is ed@zaxwerks.com
    Best,
    Edward
  • Christopher Rotter
    June 30, 2009 at 2:24 pm
    I removed that part out of my project after doing a few changes.
