Activity Forums Adobe After Effects Expressions Expressions: Leading zeros and decimal places.
  • Expressions: Leading zeros and decimal places.
    Posted by Jakub Michalski on October 30, 2005 at 12:14 pm
    For some time now I have been cracking my head tryign to figure out if there is a way to develop an expression for Text Source that would allow the number (say, driven by a calculation, or a link to slider or another effect) to be presented with leading zeros.
    Of course there is a possibility of including a large set of “if” statements, but I was hoping maybe someone knows an easier way.
    Apart from leading zeros, how about displaying a number to a certain amount of decimal places. How about placing coma separator for thousands etc?
    Say X=5738 Y=4
    is there a simple way of making them display as:
    5738 0004
    or
    5738.00 4.00
    or
    5,738 4
    etc.
    Awesomefighter Toons replied 10 years, 11 months ago 8 Members · 12 Replies
  • 12 Replies
  • Colin Braley
    October 30, 2005 at 4:49 pm
    Here is an expression for source text that should add leading zeroes to a number. Just modify the amtOfZeroes variable and pick whip the nums variable to whatever the source of your number is.
    //–Expression begins
    nums = thisComp.layer(“Deep Lime Green Solid 1”).effect(“Slider Control”)(“Slider”);
    amtOfZeroes = 10;
    //–Do not modify below this line
    isNeg = false;
    if(nums < 0) { nums = Math.abs( nums ); isNeg = true; } sVal = Math.round( nums ) + ""; while(sVal.length < amtOfZeroes) { sVal = "0" + sVal; } if(isNeg) sVal = "-" + sVal; sVal //--Expression ends ~Colin
  • Colin Braley
    October 30, 2005 at 5:00 pm
    Here is a a simple way to round a number to a specified amound of decimal places:
    Just pick whip nums to something else and change the value of the numOfPlaces variable to make it round to a different number of decimal places.
    //–Begin Expression
    numOfPlaces = 3;
    function roundTo(number, places)
    num = Math.round ( Math.pow(number, places) );
    num /= Math.pow(10, places);
    return num;
    roundTo(nums, numOfPlaces)
    //–End expression
    ~Colin
  • Jakub Michalski
    October 30, 2005 at 7:02 pm
    Wow, great!
    Would never thought of doing these loops for adding the zeros! Decimal places are perfect as well. Thank you very much – this will help me a lot in debugging my expressions!
  • Colin Braley
    October 30, 2005 at 7:18 pm
    Glad I could help.
    ~Colin
  • Drew Holzinger
    November 13, 2012 at 5:19 am
    Thanks for the expression!
    I’m using 1 decimal point.
    How can i get it to always display the decimal point when the number is whole? e.g. “3.0” or “0.0”
    also, I had to add ‘*10’ to the first line because the script was putting all the digits of the slider value behind the decimal (keyframed from 0.0 to 5.8 over 40 frames)
  • Spencer Tweed
    February 24, 2015 at 11:38 pm
    I need this for a project I’m on so I went ahead and smashed all of these expressions together. Yes, it will also do what you want with the decimal places!
    nums = PICKWHIP_VALUE_HERE;
    amtOfZeroes = 10;
    numOfDecimals = 3;
    nums = nums.value.toFixed(numOfDicemals);
    isNeg = false;
    if (nums &lt; 0)
    nums = Math.abs(nums);
    nums = nums.toFixed(numOfDecimals);
    isNeg = true;
    numsArray = nums.split(".");
    numsFloat = numsArray[0];
    while (numsFloat.length &lt; amtOfZeroes)
    numsFloat = "0" + numsFloat;
    if(isNeg)
    numsFloat = "-" + "0" + numsFloat;
    numsFloat + "." + numsArray[1]
  • Spencer Tweed
    February 24, 2015 at 11:39 pm
    Nice expressions! I modified a bit to suit my project and smashed your expressions together:
    amtOfZeroes = 10;
    numOfDecimals = 3;
    isNeg = false;
    if (nums &lt; 0)
    isNeg = true;
    if(isNeg)
  • Whitney Doug
    August 20, 2015 at 8:07 pm
    Any idea why this expression would be giving me the error: “Expected: )” on line 7, which I believe is this line: “if (nums < 0)”
  • Dan Ebberts
    August 20, 2015 at 10:15 pm
    I’d guess it’s because the poster previewed the post, which converts all < characters to html code. Dan
  • Spencer Tweed
    August 23, 2015 at 8:04 pm
    Can you post your expression? Can’t tell without seeing the code…
    – Spencer
