Activity › Forums › Adobe After Effects Expressions › expressions: inverting X and Y position
  • expressions: inverting X and Y position
    Posted by Vincent Janssen on May 21, 2008 at 9:19 pm
    hello. I’m having difficulties with some expressions. Can anybody help me out please?
    This is the problem I have:
    I have a layer in a comp that is not centred but slightly transformed to the right. Also with the height (y). Now I want to use expressions to define the new position of that layer. The amount it peaks out to the right must be inverted so it peaks out to the left with the same amount! Again also for the height.
    I used this code:
    thisComp.width-thisComp.layer(“fiets rit sequence.mov”).transform.position;
    thisComp.layer(“fiets rit sequence.mov”).transform.position-thisComp.height;
    but it doesn’t work. Although, only the first rule does work. So how do I implement these 2 rules to one good one? Or am I completely wrong and do I have to use a different code?
    I hope anyone can help me out because I have a deadline… 🙁
    Great thanks in advance!!
    Vincent Janssen replied 18 years, 4 months ago 2 Members · 3 Replies
  • Lloyd Alvarez
    May 21, 2008 at 10:11 pm
    Try this:
    x=thisComp.width-thisComp.layer(“fiets rit sequence.mov”).transform.position[0];
    y=thisComp.layer(“fiets rit sequence.mov”).transform.position[1]-thisComp.height;
    [x,y]
    _lloyd
    https://aescripts.com
  • Vincent Janssen
    May 21, 2008 at 10:15 pm
    great thanks for your reply!
    But it doesn’t work. Now it sets my layer on above my comp. And I want the difference in y to be compensated to the other side. So if my layer is 5 px over the edge on the top, it must be 5 px over the edge on the bottom.
    Thanks for your help!
  • Vincent Janssen
    May 21, 2008 at 10:36 pm
    this one does the trick!
    y=576-thisComp.layer(“fiets rit sequence.mov”).transform.position[1];
    [x,y]
    great thanks for your help!
