Activity Forums Adobe After Effects Expressions for modifying textSource makes render slow?
  • Expressions for modifying textSource makes render slow?
    Posted by Simon Robbrecht on August 24, 2010 at 10:26 am
    I have a composition with 8 text layers, the source for the text comes from another composition (in which I import text from a .csv via a script).
    When i render the very same composition in another project where the text is filled in manually (without an axpression). The render is at least 3 times faster.
    The only difference between these two projects is the source for the text layer.
    Does anyone have e clue how this is possible?
    Walter Soyka replied 16 years, 1 month ago 2 Members · 2 Replies
  • Simon Robbrecht
    August 24, 2010 at 1:06 pm
    UPDATE: if i disable the expressions, the render times are back to normal. So it looks like the mere reference to a textsource in another composition slows the whole thing down.
    Does anybody have a suggestion?
    Thank you very much
  • Walter Soyka
    August 24, 2010 at 2:12 pm
    [simon robbrecht] “UPDATE: if i disable the expressions, the render times are back to normal. So it looks like the mere reference to a textsource in another composition slows the whole thing down. Does anybody have a suggestion?”
    Maybe try this: duplicate the comp, then in your copy, convert the expression to keyframes.
    Walter Soyka
