Activity Forums Adobe After Effects Expressions: Change a value of another layer
  • Expressions: Change a value of another layer
    Posted by Tim Och on June 2, 2014 at 9:36 pm
    Hello,
    this might be a really stupid question for you, but i`m just getting started with expressions and after 2 hours of pointless searching for a solution i don`t really know what to do.
    I want to manipulate the opacity of several layers from one single null-layer, now to start i tried manipulating the value of a single layer (“layer 1”,a plain red layer).
    After trying several different functions and methods with:
    thisComp.layer("layer 1").transform.opacity
    i was stuck and now i need your help. How can i change the Opacity of “layer 1” with a expression from “null 1”
    Best Regards
    Tim
    Todd Kopriva replied 12 years, 3 months ago 3 Members · 4 Replies
  • Todd Kopriva
    June 2, 2014 at 11:08 pm
    Use property links:
    https://blogs.adobe.com/aftereffects/2013/09/after-effects-cc-12-1-whats-new-and-changed.html
    After Effects team blog
  • Tim Och
    June 3, 2014 at 12:28 pm
    thanks for your answer. What you wrote makes sense if i only want to control one layer with another layer, but i want to control 10 layer opacitys from one layer. Is this possible in any way ?
    Best Regards
    Tim
  • Michael Szalapski
    June 3, 2014 at 1:45 pm
    You can copy and paste the created expression to as many other layers as you want.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Todd Kopriva
    June 3, 2014 at 4:00 pm
    Yes. That’s what property links were designed for. Try it.
