Activity Forums Adobe After Effects Expressions expressions calculation sucks
  • expressions calculation sucks
    Posted by Arne Münch on October 20, 2017 at 11:22 am
    Hello
    I have set up a quite heavy to calculate precomp with hundreds of circles getting an individual position.
    In my master comp the precomp sits in the first two seconds (outpoint at second 2).
    If I set other things up in the master comp which are far back, lets say at second 10 or something, the precomp has to get calculated again (The green cache line disappears)
    This behavior would not occur, if it was a normal precomp without expressions, but for some reason the expressions always have to get recalculated, even though there is no change which affect the precomp.
    Are there any setting to improve this bad caching behavior when working with expressions?
    Arne Münch replied 8 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    October 20, 2017 at 4:26 pm
    You could try adding this comment to the expression:
    // cacheCompareSamplesPerSecond 0
    I don’t have any experience with it and results for others seem to be mixed, but it might be worth a try. If you try it, please report back.
    Dan
  • Arne Münch
    October 20, 2017 at 6:07 pm
    hi
    thanks for your reply.
    I have put that line to the layer positions in several precomps of my precomp.
    I don´t see any benefit from it. It has to render again although nothing important changed.
    But I have more expressions, working with linked colors and also the scale of several layers is linked.
    Does every single expression in every layer in every precomp of the precomp need that line?
    Would be a lot of work to set up.
