Activity Forums Adobe After Effects Expressions Expressions brain hurt
  • Expressions brain hurt
    Posted by Jamesc on June 29, 2006 at 5:03 pm
    Hi guys,
    I used some expressions to make this:
    https://www.mintylamb.co.uk/upload/3dengine.mp4
    Seems to work ok – but I am trying to automate it a bit more. That was all pretty much keyframed.
    It’s pretty simple – flat layers that are constantly facing the camera – linked with the rotational position. (the 3d objects are actually flat)
    I want to build this all using null objects – using a central pivot – with 18 layers around the edge.
    I’ve tried parenting null objects – making “arms” and “wrists” – sizes, anchor points – and it never seems to quite work properly.
    I am loving these expressions – but I can’t get this figured.
    James
    Jamesc replied 20 years, 2 months ago 3 Members · 3 Replies
  • Mylenium
    June 29, 2006 at 5:48 pm
    A circle is defined by sinus and cosinus, so your setup could be expressed as
    center=thisComp.layer(“Center”).position;
    radius=500;
    X=Math.sin(degreesToRadians(360/(thisComp.numLayers-1)*index))*radius;
    Y=100;
    Z=Math.cos(degreesToRadians(360/(thisComp.numLayers-1)*index))*radius;
    [X,Y,Z]
    If applied to positions, this will create a radial array of layers based on the number of layers in the composition. for the orientation, simply use auto-orient or re-build the functionality using e.g. code from my World Map tutorial.
    If you want, you can even automate the fading based on the current angle of a layer using something like linear(angle,start_angle,end_angle,100,0) (it’s a bit more complex to actually derive usable angles, but you should get the idea)
    Mylenium
    [Pour Myl
  • Mike Clasby
    June 29, 2006 at 8:05 pm
    Oooo, I like that expression, great one for us Mathmatically challenged.
  • Jamesc
    June 29, 2006 at 10:36 pm
    Excellent! Thank you so much.
    I set the auto-orient to “face camera” and set the center as the layers parents – and now I can control that perfectly.
    I also changed the code so that it only made 18 items (the max I am going to have) in the array:
    X=Math.sin(degreesToRadians(360/(18)*index))*radius;
    Y=100;
    Z=Math.cos(degreesToRadians(360/(18)*index))*radius;
    Many Thanks, James.
