Activity Forums Adobe After Effects Expressions Expressions and Sequence Layers
  • Expressions and Sequence Layers
    Posted by Stefan Van mourik on January 8, 2013 at 7:33 pm
    Hi There,
    I am fairly new to the expressions in After Effects but I’m getting really interested.
    I now have the following issue:
    Let’s say I have a comp with 5 layers. Every layer has a duration of 3 seconds and I use “sequence layers” to make them appear after each other with an overlap of 1 second.
    No biggie here.
    Now for my first layer (layer1) I have made a fade-in. 0 sec Opacity = 0%, 1 sec Opacity = 100%.
    I apply the same effect to the others, by using the expression:
    thisComp.layer(“layer1”).transform.opacity
    So that in the future, I only have to adjust my first layers timing of opacity and it will change for all the others as well, instead of copy-pasting…. (in the real project I have about 148 layers)
    Now as you might expect, this effect doesn’t work when I apply the “sequence layers” to it, since layer2 will start later than layer1 and therefore will already have a 100% opacity.
    So here is my question:
    What would the expression look like when it automatically adapts the time in between the layers?
    Just adding the time into the expression wouldn’t work, cause I would still have to go over all the layer to copy and past the expression. EG. Layer1 starts 2 seconds earlier than layer2, but layer1 starts 4 seconds earlier than layer3…
    I hope that my explanation is somehow clear to you guys. I find it hard to describe the issue with the right words 😛
    kyle watson replied 5 years, 7 months ago 3 Members · 3 Replies
  • Dan Ebberts
    January 8, 2013 at 7:56 pm
    Something like this should work:
    L = thisComp.layer(“layer1”);
    L.transform.opacity.valueAtTime(L.inPoint + time – inPoint)
    Dan
  • Stefan Van mourik
    January 8, 2013 at 8:23 pm
    Dan,
    I’m speechless!
    You’re the man. Thanks!!
  • kyle watson
    January 28, 2021 at 4:39 pm
    Also new ish to expressions. This is something that I tend to want to use a lot.
    Say I have 5 duplicated layers of a box scaling from 1-100 over 2 seconds. Each layer’s start point is offset by 20 frames. I would like to set an expression to the scale of 4 of the layers so that I can simply adjust the scale on the root layer and have it effect all.
    So I would like the applied expression to effect each layer from it’s in point. For some reason the above solution keeps breaking for me!
