Activity Forums Adobe After Effects expressions advice: multiple layers wiggling position separately random but adjustable by one “controller” layer
  • expressions advice: multiple layers wiggling position separately random but adjustable by one “controller” layer
    Posted by Jeremy Webb on October 27, 2011 at 8:18 pm
    my apologies, I didn’t realize there was a expressions-specific forum. I have reposted there.
    Hello, I have a comp that has a lot of layers that I want to wiggle in x and z position. I want them all move to a different position each frame but not as a group. I also want to be able to adjust approximately how much they move from one control laye
    what I have tried is using the seperate xyz preset and putting the wiggle expression on and for amplitude, pickwhipping a slider effect on a null layer. but this seemed to make them all move the same as if they were parented.
    how would i go about doing this
    I am not very good with expressions, but am trying to hack together something that works and would really appreciate any help
    Adam Goddard replied 13 years, 2 months ago 3 Members · 4 Replies
  • Roland R. kahlenberg
    October 28, 2011 at 2:14 am
    Two sliders will allow for better control.
    Create a Null Layer and rename it Controller.
    Apply 4 Expression Sliders to the Controller Layer and rename them as follows:
    1) X Frequency
    2) X Amplitude
    3) Z Frequency
    4) Z Amplitude
    Then paste the following script into the first layer that you want to affect. Then select its position property and select, from the Menu, Edit > Copy Expression Only. Then select all the other layers you want to affect and paste (CTRL + V)
    //Start of Script
    [wiggle(thisComp.layer(“Controller”).effect(“X Frequency”)(“Slider”),thisComp.layer(“Controller”).effect(“X Amplitude”)(“Slider”))[0],value[1],wiggle(thisComp.layer(“Controller”).effect(“Z Frequency”)(“Slider”),thisComp.layer(“Controller”).effect(“Z Amplitude”)(“Slider”))[2]]
    // End of Script
    Take note that Frequency affects the number of times per second the wiggle kicks in while amplitude is the maximum deviation (in +ve and -ve aspects) of the affected value/property.
    The Slider values can of course be keyframed to suit your needs. Lots of other ways to skin this cat but hopefully this is a start from which you can tweak the result to better suit your needs.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Jeremy Webb
    October 28, 2011 at 7:46 pm
    thanks so much roland! the cat has been sufficiently skinned and I have retained control of the skinning details.
    much appreciated
    October 29, 2011 at 6:49 am
    Awesome news Jeremy!
    Cheers
    RoRK
  • Adam Goddard
    July 9, 2013 at 5:19 am
    Hi I am trying to use this expression technique – how do I get it to wiggle the ‘y’ axis?
