Activity Forums Adobe After Effects Expressions Expression(hold opacity connected to audio keyframes)
  • Expression(hold opacity connected to audio keyframes)
    Posted by Michael Stark on June 18, 2008 at 3:09 pm
    So what I’m trying to do with no luck is this. Let’s say we have two layers of footage, and one audio layer – making it a total of 3 Layers.
    What I want to do is have the top most layer fluctuate it’s opacity according to the audio keyframes. I’m not really sure about audio keyframes but I’m sure I could figure it out. My problem also is that I don’t want the opacity to be any percentage but 0% or 100%. Aka a strobe effect according to sound.
    Just to paint a picture, I have one layer of moving 3d text, and on top of that is the exact same footage, but rendered with a glow.
    Any help would be much appreciated because I’m new to expressions and this is a tad bit advanced for me.
    Thank you.
    Rob Mcdougall replied 13 years, 11 months ago 4 Members · 4 Replies
  • Kevin Camp
    June 18, 2008 at 5:16 pm
    something like this may work:
    min = 0; //set minimum audio level
    max = 15; //set maximum audio level
    a = thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”);
    Math.round(linear(a,min,max,0,1)) * 100
    ‘a’ is the audio amplitude parameter for your audio layer. set ‘min’ and ‘max’ as needed for your audio levels… the layer will be 100% opacity when audio levels are above the midpoint of the audio range, and it will be 0% when levels are bellow that point….
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Michael Stark
    June 18, 2008 at 7:26 pm
    Thank you for your help. I will try it out and let you know how it works!
  • Carlos Lerias
    August 31, 2012 at 7:53 pm
    Hi Kevin.
    I have a similar situation to the one expressed above. The difference though is that I want to make the opacity change with the sound of a person talking. I want the image fade in fast when the person talks and I want the image to fade out slowly in the moments of silence.
    I was wondering if you could give me advice on this matter.
    All the best
    Carlos
  • Rob Mcdougall
    October 12, 2012 at 11:12 am
