Activity Forums Adobe After Effects Expression Z position
  • Expression Z position
    Posted by Frank Ruggiero on January 23, 2007 at 7:04 pm
    Does anyone know an expression in which i can have 1 layers Z space control the other. I want to link many 3d layers to a null, but when I animate the null, i want the layers to push out at different rates.
    DOes that make sense?
    FRank
    Kevin Camp replied 19 years, 3 months ago 2 Members · 3 Replies
  • Kevin Camp
    January 23, 2007 at 7:29 pm
    use the pick whip to link each layer’s z pos to the null layer’s z pos. then just add a mulitiplier at the end each layer’s expression, like *2 or *.5
  • Frank Ruggiero
    January 23, 2007 at 7:55 pm
    Hi, Thanks for your response. Would you be able to tell me how I can just choose the Z position. I see that I can link it with the pick whip to another layer’s z position. But how do you just choose the Z for the layer that is going to be affected?
  • Kevin Camp
    January 23, 2007 at 8:09 pm
    sorry… twirl down the z position properties for the null layer and the layer you want to link. then select the z pos property of the layer that will be linked and choose add expression from the animation menu.
    this should bring up another line of options/icons under the z position. in that line there is a pick whip, drag that pick whip to the z pos property of the null. now there should be some text in the field to the right of the pick whip (and other) icons for z pos. that property is now linked to the propery of you null.
    if you add your multiplier to the end of that text it will offset the z pos of that layer in respect to the z pos of your null.
