Activity Forums Adobe After Effects Expressions Expression works, but “doesn’t”
  • Expression works, but “doesn’t”
    Posted by Mike Nielsen on June 26, 2011 at 4:19 pm
    Hi Folks
    I have an expression that uses a slider manipulate some settings for camera z-position and zoom value…I finally got the math right – I can see the right values returned by the expression to the camera properties.
    Problem is: the result is wrong – totally different as opposed to just typing in parameters by hand…
    Any ideas?
    (Don’t have the exact setup with me just now,- left it at my office…)
    Mike
    Mike Nielsen replied 15 years, 2 months ago 2 Members · 4 Replies
  • Dan Ebberts
    June 26, 2011 at 7:04 pm
    Hard to say. Maybe you need a layer space transform in there somewhere, if anything is parented. I’d really need to see the code.
  • Mike Nielsen
    June 26, 2011 at 7:09 pm
    Thanks for the reply, Dan – makes sense. I’ll update here as soon as I get to the project tomorrow…
    Kind regards,
    Mike
  • Mike Nielsen
    June 27, 2011 at 7:49 am
    Updating my question with some specific info:
    Setting keyframes by hand (no code whatsoever) for the camera:
    At frame 001: position: 960, 540, -2618 zoom: 800 pixels
    At frame 100: position: 960, 540, -1800 zoom: 342 pixels
    This produces the desired animation, that I was hoping to control by a slider:
    Slider: clamp(value, min=342, max=800)
    Camera zoom is pick-whipped to the slider…
    Camera Z position code: cameraOption.zoom*1.786-3228.82
    Argg, update: I now see, that I’m getting the right numbers but somehow my math is off!
    Help appreciated, thanks:o)
    Kind regards,
    Mike
  • Mike Nielsen
    June 27, 2011 at 11:07 am
    Fixed the problem – turns out my math was wrong after all, duh…
    Thanks…
    Mike
