Activity Forums Adobe After Effects Expression Won’t Render
  • Expression Won’t Render
    Posted by Benny Christensen on September 30, 2005 at 6:18 pm
    My name is Benny and I’m very Expressions Challenged.
    I’m using AE6.5 with a G5 dual 2gig with lots of RAM.
    I’ve modified an expression from Dan Ebberts site to make some blocks move randomly along the X axis. It plays fine, but when I try to render it starts popping up all sorts of errors.
    Any ideas?
    Thanks.
    Benny Christensen
    Producers Playhouse
    Oklahoma City, OK
    G5 Dual 2 Gig – 10.4.2 – 4 Gb RAM – FCP 5.02 – KONA2 – ATTO UL4D – HUGE 320RX – Convergent Designs SD-Connect
    Dan Ebberts replied 20 years, 11 months ago 3 Members · 4 Replies
  • Dan Ebberts
    September 30, 2005 at 8:10 pm
    What do the error messages say?
    Dan
  • Steve Roberts
    September 30, 2005 at 8:14 pm
    … and can you copy and paste the expression (from your project) in your post?
    Steve 🙂
  • Benny Christensen
    September 30, 2005 at 8:37 pm
    First – Here is the error message After Effects Warning: Class ‘global’ has no property or method named ‘start’. Error ocurred at line 18. Expression disabled.
    I found that if I start the render somewhere after 3 or 4 seconds it would work.
    Second – Here is the expression
    tMin = .25; //minimum segment duration
    tMax = 1.0; //maximum segment duration
    minVal = [0.*thisComp.width, 0*thisComp.height];
    maxVal = [1*thisComp.width, 0*thisComp.height];
    end = 1;
    j = 2;
    while (time >= end){
    j ++;
    seedRandom(j,true);
    start = end;
    end += random(tMin,tMax);
    endVal = random(minVal,maxVal);
    seedRandom(j-1,true);
    dummy = random(); //this is a throw-away value
    startVal = random(minVal,maxVal);
    ease(time,start,end,startVal,endVal)
    Thanks.
  • Dan Ebberts
    September 30, 2005 at 9:21 pm
    Yeah, it looks like you made some changes to the expression that cause start to be undefined near the beginning of the comp. If you just want random movement in the x direction, you could try this one:
    segMin = .3; //minimum segment duration
    segMax = .7; //maximum segment duration
    minVal = 0;
    maxVal = thisComp.width;
    end = 0;
    j = 0;
    while ( time >= end){
    j += 1;
    seedRandom(j,true);
    start = end;
    end += random(segMin,segMax);
    dummy=random(); //this is a throw-away value
    y = position[1];
    ease(time,start,end,[startVal,y],[endVal,y])
    Dan
