Activity Forums Adobe After Effects Expressions Expression value to a keyframe
  • Expression value to a keyframe
    Posted by Vera Steinbeck on March 7, 2019 at 12:24 pm
    hi there!
    yesterday i searched for a good way to give my first keyframe a value and my second keyframe another value.
    logical (for me) it would be like this:
    s = thisComp.layer("control").effect("example")("example");
    key(1).value = 0;
    key(2).value = s;
    but i found a solution in this forum where it was told that i have to go via keytime, like this:
    (had to put it to the end of the post)
    the second code works fine, buti think, this is far to complicated to solve my problem.
    does anybody have a better approach to this?
    max = thisComp.layer("control").effect("example")("example");
    min = 0;
    t1 = key(1).time;
    t2 = key(2).time
    if (time<=t1) min;
    else if (time>t1 && time<t2) ease(time,t1,t2,min,max);
    else max;
    Vera Steinbeck replied 7 years, 5 months ago 2 Members · 2 Replies
  • Alex Printz
    March 7, 2019 at 4:31 pm
    You cannot push values into keys, only pull. You would do like this:
    t1 = key(1).time;
    t2 = key(2).time;
    v1 = 0;
    v2 = thisComp.layer("control").effect("example")("example");
    linear(time,t1,t2,v1,v2)
    note that you cannot adjust the curves with this; you are only looking at when these keys are set.
    If you want to be able to adjust the slope, set the keys to have different property values (e.g, Key 1: 100, key 2:200), and try this:
    p1 = key(1).value;
    p2 = key(2).value;
    v1 = 0;
    linear(value,p1,p2,v1,v2)
    Note this second expression depends on the keys having different input property values and understanding that your property is going to convert the change in property values into a similar change between your two defined values!
    Alex Printz
    Mograph Designer
  • Vera Steinbeck
    March 11, 2019 at 2:28 pm
    thank you alex!
