Activity › Forums › Adobe After Effects Expressions › Expression value not working when pick whipped. Sometimes.
  • Karl Gonsalves
    August 30, 2022 at 2:41 am
    *Using just THE values I’d like it to effect the zPosition …
  • Tomas Bumbulevičius
    August 31, 2022 at 9:09 am
    Hey Karl, that is strange behaviour indeed! It seems that on Z it works only when the exact same expression is applied again.
    I also checked in case there is some rounding happening – doesn’t seem to be the case neither.
  • Karl Gonsalves
    August 31, 2022 at 11:47 am
    Hi Tomas.
    Thanks for looking into this for me. 🙂
    Yes; I did consider copying the same expression on the Z, but assumed it would mean more computing!?
    NOTE: The expression works as intended if I place the script slider on the null.
    The null allows me to place/move the square easily on the comp for now. I plan to fill up the screen with the squares. Kind of making it appear like a vortex. Once in place, I’d delete the nulls. Wanting to recreate something like this.
    https://mobile.twitter.com/madebykaran/status/1561925886299217920?cxt=HHwWgIDRpa7Uia0rAAAA
  • Karl Gonsalves
    September 1, 2022 at 1:55 pm
    Update:
    More layers than I would have liked. Double the number because of the NULLs.Orientation has gone out of whack but should be able to fix that.
