Activity Forums Adobe After Effects Expressions Expression to use the time between two keyframes?
  • Expression to use the time between two keyframes?
    Posted by David Cabestany on July 24, 2019 at 4:15 pm
    I’m trying to link a property in a layer to the time elapsed between two keyframes, so instead of defining the duration as .5 seconds for example, I define it as whatever the time lasts in between regardless of how I move those keyframes in the timeline in different compositions.
    Any ideas?
    Thanks.
    David Cabestany replied 7 years, 1 month ago 2 Members · 2 Replies
  • Dan Ebberts
    July 24, 2019 at 7:02 pm
    Something like this, probably:
    prop = thisComp.layer(“Layer 1”).position;
    t1 = prop.key(1).time;
    t2 = prop.key(2).time;
    dur = t2 – t1;
    Dan
  • David Cabestany
    July 30, 2019 at 3:44 pm
    Thanks Dan, yes, I figured it almost right away, felt pretty silly afterward, I thought a more complex expression was needed.
