Activity Forums Adobe After Effects Expressions Expression to switch/change between same characters?
  • Expression to switch/change between same characters?
    Posted by Kazimir Bielecki on December 7, 2016 at 1:33 pm
    Hello,
    I need to create a method or expression to switch/change between same characters within a word.
    For instance…
    CAT, could alternate between, ACT, TCA, ATC, TAC and so on.
    I’ve tried adding a character offset from the animate button but when I cycle the offset is gives me a completely different set of numbers and letters.
    If there is a method/expression, is it possible to be able to use the same expression at different speeds and with different text?
    I would appreciate some help on adding some expressions to do this. I am a rookie looking to learn.
    Dan Ebberts replied 9 years, 8 months ago 2 Members · 1 Reply
  • Dan Ebberts
    December 7, 2016 at 6:29 pm
    Something like this might work:
    dur = 1; // change every second
    txt = value;
    seg = Math.floor(time/dur);
    seedRandom(seg,true);
    a = [];
    for (i = 0; i < txt.length; i++) a.push(i);
    for (i = 0; i < txt.length; i++){
    idx = Math.floor(random(txt.length));
    temp = a[i];
    a[i] = a[idx];
    a[idx] = temp;
    outStr = "";
    outStr += txt[a[i]];
    outStr
    Dan
