Activity › Forums › Adobe After Effects Expressions › Expression to switch on objects beneath matte
  • Expression to switch on objects beneath matte
    Posted by Matthew Ingram on January 1, 2015 at 8:23 pm
    hi there
    i’m working on a personal project for which i would greatly appreciate some help.
    i’m wondering if there is a way of “switching on” the visibility of objects beneath a matte.
    the areas (they might be individual letters) can’t be cropped/clipped by the matte – they have to be either switched on or off in a way that creates an aliased edge.
    here’s a visual example of what i mean if i’m not being clear. the red line denotes the edge of the matte.
    Matthew Ingram replied 11 years ago 2 Members · 8 Replies
  • 8 Replies
  • Matthew Ingram
    January 4, 2015 at 4:52 pm
    really hoping someone has an idea on this 🙂
  • Dan Ebberts
    January 4, 2015 at 6:59 pm
    Assuming the matte is a layer, something like this should work:
    m = thisComp.layer(“matte”);
    p = m.fromComp(toComp(anchorPoint));
    a = m.sampleImage(p,[width,height]/2,true,time)[3];
    a < .5 ? 0 : 100
    Dan
  • Matthew Ingram
    January 4, 2015 at 7:27 pm
    thanks dan – i’m honoured by your presence.
    i applied it to the transparency of the layers below and (as the saying goes) BOOM. perfect.
  • Matthew Ingram
    September 2, 2015 at 1:55 pm
    hi dan (or if anyone else is tuned in…)
    is there a way to tailor this script so that the layers scale up from zero rather than their opacity switches on?
    would be great to know!
    many thanks.
  • Dan Ebberts
    September 2, 2015 at 4:44 pm
    Let me ask you this–is there any animation going on, or, if a layer is under the matte, it’s always under the matte? (It makes a big difference to how complicated the expression would be).
    Dan
  • Matthew Ingram
    September 2, 2015 at 5:11 pm
    thanks dan 🙂
    apart from the scaling up – no there wouldn’t be any other animation (they are preComps – so i can put animation in there)
    yes – everything could be under the matte.
    very much appreciated
    matt
  • Dan Ebberts
    September 2, 2015 at 5:21 pm
    Something like this then probably:
    m = thisComp.layer("matte");
    scaleTime = .5;
    if (a < .5){
    [0,0];
    }else{
    ease(time,inPoint,inPoint+scaleTime,[0,0],[100,100])
    Dan
  • Matthew Ingram
    September 3, 2015 at 5:07 pm
    beautiful. thank you 🙂
