Activity Forums Adobe After Effects Expressions Expression to stop rendering when there are no pixels in the composition
  • Expression to stop rendering when there are no pixels in the composition
    Posted by Avinash Ramanath on December 21, 2016 at 9:57 am
    Scenario: Text crawler
    I am dynamically passing a string to a text layer which is crawling at below speed
    rate = 2; //value in px/sec.
    value – [rate*timeToFrames(time),1]
    This text layer is placed inside a comp named RenderComp which I will render as TGA using Media Encoder.
    Requirement:
    The standard duration of RenderComp is set to 5 minutes. Is there a way to dynamically set the timing of the composition based on the string length, so that it does not render blank frames when the string is shorter.
    value - [rate*timeToFrames(time),1]
    Dan Ebberts replied 9 years, 8 months ago 2 Members · 3 Replies
  • Dan Ebberts
    December 22, 2016 at 5:13 pm
    Expressions can’t control the work area or anything else I can think of that would give you the result you’re looking for. You could do it with a script though.
    Dan
  • Avinash Ramanath
    December 22, 2016 at 5:47 pm
    Dan, I am new to scripting, could you please help me with a script that does what am looking for.
    Pick a footage/footages from a folder (say video1 and video2)
    Import the files inside after effects
    make compositions from the videos
    sequence the compositions
    Render the composition
    I know am asking too much, could you please direct me towards ways of achieving this even if i have to approach an agency.
    Thanks in advance.
  • Dan Ebberts
    December 22, 2016 at 6:24 pm
    This is a simple example that asks you to navigate to a video file and then creates a comp with it.
    function makeComp(){
    var video1 = File.openDialog("Navigate to video file.");
    if (video1 == null || (! video1.exists)){
    alert("No video selected.");
    return;
    var myImportOptions = new ImportOptions;
    myImportOptions.file = video1;
    var myFootage = app.project.importFile(myImportOptions);
    var myComp = app.project.items.addComp("video1",myFootage.width,myFootage.height,myFootage.pixelAspect,myFootage.duration,myFootage.frameRate);
    myComp.layers.add(myFootage);
    makeComp();
    Hopefully that will get you started.
    Dan
