Activity Forums Adobe After Effects Expression to simulate a pixie flapping it’s wings
  • Expression to simulate a pixie flapping it’s wings
    Posted by Joseph Wilkins on June 16, 2021 at 10:43 pm
    I have two wings that are on two separate layers – both under the person.
    I have 3D turned on and want to get an expression that flaps them at near humming-bird speed.
    I’m playing with wiggling the Y rotation of each wing without much luck. Nothing looks fast enough or real enough.
    Does anyone have an expression they can share? Thanks!
    Joseph Wilkins replied 5 years, 3 months ago 2 Members · 3 Replies
  • Kevin Camp
    June 16, 2021 at 11:56 pm
    This may work for you, just add it to the rotation axis that you want the wings to rotate on.
    upRot = 45 ;
    dwnRot = -45 ;
    freq = 10 ; // times per sec
    ease( Math.cos( time * 2 * Math.PI * freq ), -1, 1, upRot, dwnRot )
    The upRot and dwnRot values are essentially the min and max rotations for the wings (set as needed). Then adjust the freq of the flapping — according to the internet, a humming bird beats it’s wings between 10 and 80 time a second.
    If you wanted to add some randomness, you can literally add some wiggle() to the end of the last line:
    ease( Math.cos( time * 2 * Math.PI * freq ), -1, 1, upRot, dwnRot ) + wiggle( 5, 10 )
  • Kevin Camp
    June 17, 2021 at 1:56 am
    Actually, to make the upRot the maximum upwards angle, I should have use the sine function… the last line should be like this:
    ease( Math.sin( time * 2 * Math.PI * freq ), -1, 1, upRot, dwnRot )
  • Joseph Wilkins
    June 17, 2021 at 12:29 pm
    Thank you SO much! 🙂
