Activity Forums Adobe After Effects Expressions expression to show comments and duration between markers :)
  • expression to show comments and duration between markers :)
    Posted by Chifei Soong on May 25, 2012 at 9:22 am
    source text expression:
    small expression to display duration between markers in layer.
    (modified from Dan’s marker expression)
    need help:
    now the expressions gets the time from nearest markerKey, need to make the expression hold until the next marker, so that the value wont change half-way between 2 markers
    Thanks 😀
    p=thisLayer; //layer where the markers is
    if (p.marker.numKeys > 0) try{
    n = p.marker.nearestKey(time).index;
    m = p.marker.key(n).time; m2=p.marker.key(n+1).time;
    c=p.marker.key(n).comment;
    v=m2-m;
    catch(err){ c=p.marker.key(n).comment; m=0; m2=p.marker.key(n).time; m3=thisComp.duration; v=m3-m2;}
    c+"r"+timeToTimecode(v)
    Chifei Soong replied 6 years, 6 months ago 2 Members · 3 Replies
  • Dan Ebberts
    May 25, 2012 at 4:26 pm
    I think you’re after something like this:
    m = thisLayer.marker; //layer where the markers is
    n = 0;
    if (m.numKeys > 0){
    n = m.nearestKey(time).index;
    if (m.key(n).time > time) n--;
    if (n == m.numKeys){ // after last marker
    t = thisComp.duration - m.key(n).time;
    c = m.key(n).comment;
    }else if (n == 0){ // before first marker
    t = m.key(1).time;
    c = "";
    }else{ //between two markers
    t = m.key(n+1).time - m.key(n).time;
    }else{ // no markers
    t = thisComp.duration;
    c = "";
    c + "r" + timeToTimecode(t)
    (note that the “r” in the last line should be “(backslash)r”
    Dan
  • Chifei Soong
    May 25, 2012 at 4:54 pm
    Yes it works perfectly as i wanted.
    🙂 thanks Dan!
  • Chifei Soong
    February 29, 2020 at 8:42 am
    Hi Dan
    I just wanted to thank you again.
    8 years, this script still serving me well ????
