Activity Forums Adobe After Effects Expressions Expression to return last value when Checkbox is enabled
  • Expression to return last value when Checkbox is enabled
    Posted by Jacob Roth on June 21, 2018 at 1:01 pm
    Hi everybody,
    So I’m trying to combine solutions from Dan Ebberts and it’s not working so far.
    I have the falling leaf effect that Dan wrote here:
    https://www.aenhancers.com/viewtopic.php?t=8
    And I’m trying to combine it with his code to return the last expression value at time here:
    https://forums.creativecow.net/thread/227/34463
    It’s not really working, and I don’t know how to fix it. The code I’ve attached is on position.
    Any ideas?
    yVelocity = 200; //pixels per second
    oscFreq = thisComp.layer("Null 1")("Effects")("Oscillation Frequency")("Slider"); //oscillations per second
    oscDepth = 35; //oscillation depth (pixels)
    drift = 25; // drift (wind?) (pixels per second: - = left, + = right)
    chkBx = thisComp.layer("Null 1")("Effects")("Stop")("Checkbox");
    n = 0;
    if (chkBx.numKeys > 0){
    n = chkBx.nearestKey(time).index;
    if (chkBx.key(n).time > time) n--;
    t = 0;
    curTime = time;
    if (n > 0){
    for (i = n; i > 0; i--){
    if (chkBx.key(i).value > 0){
    t += (curTime - chkBx.key(i).time);
    curTime = chkBx.key(i).time;
    if ((curTime > 0) && (chkBx.key(1).value > 0)) t += curTime;
    }else{
    value + [oscDepth*Math.sin(oscFreq*Math.PI*2*time) + drift *time,
    yVelocity*time,0]
    Jayden Bradley replied 8 years ago 3 Members · 6 Replies
  • Dan Ebberts
    June 21, 2018 at 1:19 pm
    I think what you need to do is replace time in falling leaf expression with the t variable calculated in the checkbox expression, like this:
    n = 0;
    t = 0;
    curTime = time;
    if (n > 0){
    }else{
    if (chkBx.value > 0) t = time;
    value + [oscDepth*Math.sin(oscFreq*Math.PI*2*t) + drift*t,
    yVelocity*t,0]
    Dan
  • Jacob Roth
    June 21, 2018 at 1:34 pm
    Yep, that did it.
    How translatable is the checkbox control for pausing an expression to other types of expressions. Like, if I want to be able to pause a wiggle?
  • Dan Ebberts
    June 21, 2018 at 3:32 pm
    You would just need to use t for wiggle’s 5th parameter (time):
    n = 0;
    t = 0;
    curTime = time;
    if (n > 0){
    }else{
    wiggle(1,100,1,.5,t)
    Dan
  • Jacob Roth
    June 21, 2018 at 5:46 pm
    Dan you’re blowing my mind. I didn’t even know there were third and fourth parameters to the wiggle expression. What do they control?
  • Dan Ebberts
    June 21, 2018 at 6:13 pm
    They control number of octaves and the influence of each octave in the noise wave, allowing you to make the wiggle more frenetic. I don’t think I’ve ever used them, except to get to the time parameter.
    Dan
  • Jayden Bradley
    August 15, 2018 at 3:39 pm
    Hey, guys. Helpful information so far, however, i would like some help as to how to translate this time/t for other expressions. For e.g overshoot by Dan.
    freq = 2;
    decay = 5;
    delay = .15;
    dur = .12;
    myDelay = (textIndex-1)*delay;
    t = time - (inPoint + myDelay);
    startVal = 100;
    endVal = 0;
    if(t < dur){
    linear(t,0,dur,startVal,endVal);
    }else{
    amp = (endVal - startVal)/dur;
    w = freq*Math.PI*2;
    endVal + amp*(Math.sin(t*w)/Math.exp(decay*t)/w);
