Activity Forums Adobe After Effects Expression to Read Timecode of main / outer comp
  • Expression to Read Timecode of main / outer comp
    Posted by Ace Billet on April 1, 2011 at 8:48 pm
    I have a video with some User Interface animations.
    I want to include a time code on all the instances of that GUI,
    BUT… I don’t want it to read its own comp’s TC (beacuse this would be 00:01 and going… and then next time it will also start from 00:00)
    It should read the main / outside comp. So whenever you see the time code, it’s in sync
    with the real time. The GUI itself is nested about 5 comps deep in the “main” comp.
    Is there an effect combined with an expression that can pull this off ?
    cheers
    Billet
    <== BilletHQ | Creative that Goes to 11 ==>
    https://www.billethq.com
    Erik Waluska replied 15 years, 5 months ago 2 Members · 1 Reply
  • Erik Waluska
    April 3, 2011 at 4:41 pm
    I would just pre-compose the timecode from within the comp you want to use as the source of the timecode and then drop that pre-comp in whatever other comp you want to use it in.
    Or, you can build an expression-based timecode clock and link across comps to the one you want to use as the source. Check this out…
    https://aenhancers.com/viewtopic.php?t=21
