Activity Forums Adobe After Effects Expressions Expression to read Marker from any Null layer – is this possible.
  • Expression to read Marker from any Null layer – is this possible.
    Posted by Pablo Beckett on August 30, 2022 at 6:54 pm
    Is it possible to read the Marker time from any Null layer regardless of the layers name.
    Essentially I’d like to have a control layer which will iterate through every layer within a comp and if the layer has a marker on it it will trigger an expression, much the same as the ‘Opacity Flash – layer markers’ preset but for any layer which has a marker.
    I don’t want to have to point the expression to a specific layer or multiple layers, the only condition required it the layer(s) have markers.
    I imagine the starting point for this would be a ‘For Loop’ but I’m not sure.
    Many thanks in advance…
    Pablo Beckett replied 4 years ago 2 Members · 3 Replies
  • Dan Ebberts
    August 30, 2022 at 9:21 pm
    Probably something close to this:
    tMin = null;
    for ( i = 1; i <= thisComp.numLayers; i++){
    if (i == index) continue;
    m = thisComp.layer(i).marker;
    if (m.numKeys == 0) continue;
    n = m.nearestKey(time).index;
    if (time < m.key(n).time) n--;
    if (n > 0){
    t = time - m.key(n).time;
    if (tMin == null){
    tMin = t;
    }else{
    tMin = Math.min(tMin,t);
    tMin == null ? 0 : tMin
  • Dan Ebberts
    August 30, 2022 at 11:48 pm
    I forgot to mention, as-is, you could use this to drive a time-remapped animation. If you wanted to use it to drive some other animated property, you’d probably want to change the last line to:
    valueAtTime(tMin == null ? 0 : tMin)
  • Pablo Beckett
    August 31, 2022 at 9:43 am
    Amazing, thanks Dan. Works like a charm.
