Activity Forums Adobe After Effects Expressions Expression to randomize a size of an object
  • Expression to randomize a size of an object
    Posted by Alessio Rattazzi on August 15, 2023 at 9:01 am
    I would like the size of my object to change randomly (maintaining the height-width proportion), ideally being able to manage how many changes occur per second and the minimum and maximum size the object can have.
    The closest expression to what I want to achieve that I found is wiggle, but it does not allow me to control all the values as I would like (e.g. the scale is not maintained).
    Thank you very much in advance for your help and time
    Best Alessio
    Brie Clayton replied 3 years ago 3 Members · 3 Replies
  • Dan Ebberts
    August 15, 2023 at 4:33 pm
    Maybe a wiggle expression like this:
    min = 20;
    max = 80;
    freq = 2;
    center = (min + max)/2;
    amp = (max - min)/2;
    w = wiggle(freq,amp) - value;
    [center,center] + [w[0],w[0]]
  • Alessio Rattazzi
    August 16, 2023 at 2:53 pm
    Thanks a lot Dan! It works perfectly!
    Best Alessio
  • Brie Clayton
    August 17, 2023 at 2:03 pm
    Thank you for the solve, Dan!
