Activity › Forums › Adobe After Effects Expressions › Expression to pull name of group of layers?
  • Expression to pull name of group of layers?
    Posted by Ben Cone on July 31, 2015 at 4:21 pm
    Hey guys, so I have a set of layers that moves x amount based on how many layers there are involved.
    Is there any way to pull the amount of layers there are in a comp with a name starting with some string? I basically want to be able to add as many layers with some modifier so that the expression works regardless.
    For example, all the layers might start with “01_” or something and then any time the expression sees that it could add that to the sum of layers.
    Thanks in advance
    Xavier Gomez replied 11 years, 1 month ago 2 Members · 1 Reply
  • Xavier Gomez
    July 31, 2015 at 4:46 pm
    To retrieve that number, you can use
    num = 0;
    str = “01_”;
    N=thisComp.numlayers;
    for (n=1; n<=N; n++){if (thisComp.layer(n).name.indexOf(str)===0) ++num;}; // at this stage, num is the number of layers in the comp whose name starts with "01_". // then you use it to calculate your position offset. Xavier
