Hey Kevin, do those pins has particular order?
Instead of keyframing them all and having to work with a bunch of the same animation around multiple layers, I would suggest to animate only a single item / master, and then link others with delay based from it.
In case if different order of appearance is required, it would need to only shift layers stack.
1. Create null and call it ‘control’.
2. Add slider effect to it and call it ‘delay’ (this will be ‘offset time’)
3. Add slider effect and call it ‘yPos’
4. Animate yPos to reflect pin movement from its original position.
5. Link your master layer’s y position to ‘yPos’ slider: position[1] + yPos (might need to tweak this depending on pos differences)
6. Apply expression below depending on whether your master is above or below (index+1) or (index-1)
7. Adjust ‘position’ value to match your design needs.
delayFrames = thisComp.layer("control").effect("delay")(1);
delay = framesToTime(delayFrames);
thisComp.layer(index+1).transform.position.valueAtTime(time-delay) //needs custom update to reflect relative yPos
Find out more:
After Effects Tutorials: motion design, expressions, scripting.
Boxer – Dynamic Text Boxes Template with a Live Preview
