Activity Forums Adobe After Effects Expressions Expression to move camera at steady speed with slider control
  • Expression to move camera at steady speed with slider control
    Posted by Gerhard Human on August 7, 2020 at 6:47 am
    Hi all.
    I’m trying to do something rather simple but it’s breaking my head.
    I have a bunch of cameras at different positions in the timeline. They all need to move on the Z axis at a steady constant speed but at some point I need to stop one of the cameras.
    So I’ve been using the script below, placed on each of the cameras.
    It works perfectly but I’ve tried a number of ways to get the camera to stop but I can’t figure out how to determine the last value of the position applied by the script. It keeps going back to the original layer position.
    Is there a way to move the position without using the “time” expression?
    (something like currentPosition += 10 and then you can substitute the 10 with a slider or something like that 😛 )
    var CamSpeed = thisComp.layer("Adjustment Layer 1").effect("Cam_Speed")("Slider");
    var PULL = value[2]-(time*CamSpeed);
    [value[0],value[1],PULL];
    Gerhard Human replied 6 years, 1 month ago 2 Members · 4 Replies
  • Andrei Popa
    August 7, 2020 at 7:13 am
    You could put a marker on the camera layer at the point that you want it to stop and use this expression
    var PULL = time < marker.key(1).time ? value[2] - time * CamSpeed : value[2] - marker.key(1).time * CamSpeed;
    [(value[0], value[1], PULL)];
    Andrei
    My Envato portfolio.
  • Gerhard Human
    August 7, 2020 at 7:21 am
    Thanks Andrei, really appreciate it.
    OK please excuse my incompetence but I’m not getting the marker bit… I added a marker on the main timeline (shift+1, or even manually adding a marker with no name, also named it 1 manually) I also tried adding a marker on the actual camera where the script is situated but I keep getting the error: “expression result must be of dimension 3, not 1”
    Am I missing something?
  • Andrei Popa
    August 7, 2020 at 7:29 am
    It’s my mistake. I am sorry, the autocorrect on my text editor added parenthesis on the last lane for no reason. Here is the actual expression.
    [value[0], value[1], PULL];
    Andrei
  • Gerhard Human
    August 7, 2020 at 7:33 am
    You sir are a legend. Thanks so much. Works perfectly ☺
    Really appreciate it
