Activity Forums Adobe After Effects Expressions Expression to make objects to move out at random from source object in center of screen
  • Expression to make objects to move out at random from source object in center of screen
    Posted by David Mathis on December 12, 2013 at 3:04 pm
    Looking to create an expression that would make a circles go out in different directions from a circle in the middle of the screen. I saw a video on something similar to this one time but can not remember the expression that was used. I do remember, however, that a wiggle expression was involved.
    Also, what books are recommended for learning expressions? Some stuff I understand other stuff keeps slamming me into a brick wall.
    George Goodman replied 12 years, 8 months ago 3 Members · 2 Replies
  • Kevin Camp
    December 12, 2013 at 6:26 pm
    try this:
    target = thisComp.layer('center layer'); // your center circle layer
    area = [800,800]; // value in pixels
    dur = 3; // value in seconds
    seedRandom(index,true);
    p1 = target.position;
    p2 = random(p1-area,p1+area)
    linear(time-inPoint, 0, dur, p1, p2)
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • George Goodman
    December 13, 2013 at 4:58 am
    If your circle is a shape layer, you could just use wiggle transform. All you would need to do is duplicate it a bunch of times and add the wiggle transformer to the bottom of all the shapes. Take wiggles per second to 0 and then keyframe the position under it’s transform from 0,0 to 3049,4256 … or whatever last value works in getting them all off screen.
    “|_ (°_0) _|”
    Sincerely,
    George
