Activity Forums Adobe After Effects Expressions Expression to maintain equal spacing between objects
  • Expression to maintain equal spacing between objects
    Posted by Tim Boknecht on September 25, 2012 at 8:31 pm
    I have 11 rotating rings that I want to space out equally on the z axis with a slider. In other words, if I adjust the slider I want the rings to space out while remaining equidistant from each other on the z axis while the x and y axes remain unchanged.
    Should be easy, right?
    Tim Boknecht
    Media Producer
    Bravo Productions
    Tim Boknecht replied 13 years, 12 months ago 1 Member · 1 Reply
  • Tim Boknecht
    September 25, 2012 at 9:23 pm
    Kept researching while waiting for an answer. Found the solution at Video Copilot (Andrew Kramer rocks). Posting here for future seekers.
    Pretty easy, actually. Just create a slider and name it “Control”, then paste the expression below to the position property of each 3D layer you want to affect.
    Brilliant!
    value+[0,0,index*thisComp.layer("Control").effect("Slider Control")("Slider")]
    Tim Boknecht
    Media Producer
    Bravo Productions
