Activity Forums Adobe After Effects Expressions Expression to loop a layer property which has expression on it.
  • Expression to loop a layer property which has expression on it.
    Posted by Mac Lad on May 12, 2021 at 11:43 pm
    Hi guys, I have a layer which basically animates from one point to other point on x-axis which has a custom speed values and duration of 2 secs. Currently I am achieving this by below expression function
    function customBezier(t,tMin,tMax,value1,value2,bezierPoints){if(arguments.length!==6)return value;var a=value2-value1;var b=tMax-tMin;var c=clamp((t-tMin)/b,0,1);if(!(bezierPoints instanceof Array)||bezierPoints.length!==4)bezierPoints=[0,0,1,1];return a*h(c,bezierPoints)+value1;function h(f,g){var x=3*g[0];var j=3*(g[2]-g[0])-x;var k=1-x-j;var l=3*g[1];var m=3*(g[3]-g[1])-l;var n=1-l-m;var d=f;for(var i=0;i<5;i++){var z=d*(x+d*(j+d*k))-f;if(Math.abs(z)<1e-3)break;d-=z/(x+d*(2*j+3*k*d));}return d*(l+d*(m+d*n));}}
    t = time;
    dur = 2;
    startVal = 200;
    endVal = 800;
    customBezier(t,0,dur,startVal,endVal,[0.76, 0, 0.24, 1]);
    Is there anyway that I could loop this animation just like using pingpong expression on two keyframes.
    Thank You
    Mac Lad replied 5 years, 4 months ago 2 Members · 4 Replies
  • Dan Ebberts
    May 12, 2021 at 11:51 pm
    Try replacing everything after the function with this:
    dur = 2;
    n = Math.floor(time/dur);
    t = n%2 ? dur - time%dur : time%dur;
    startVal = 200;
    endVal = 800;
  • Mac Lad
    May 12, 2021 at 11:57 pm
    It works…Thank you Dan. Is it possible to explain what does t = n%2 ? dur – time%dur : time%dur; does here
  • Dan Ebberts
    May 13, 2021 at 12:44 am
    n is the count of how many 2-second periods there have been. n%2 tells you whether n is odd or even. For the odd-numbered periods, you want t to go backwards (by subtracting time%dur from dur) otherwise, go forwards (just time%dur). time%dur gives you the remainder of of the time/dur operation, and is what generates the looping.
  • Mac Lad
    May 13, 2021 at 7:29 am
    Thanks Dan for explaining.
