Activity Forums Adobe After Effects Expressions Expression to link shape object ‘paths’ but minus x pixels
  • Expression to link shape object ‘paths’ but minus x pixels
    Posted by Lance Clayton on April 10, 2014 at 1:27 am
    I need the correct expression to link the paths of two shape layer shapes, but such that one is x pixels smaller than the other, thus creating in inner and outer box as in the example pick.
    I want to move the path of only one of the shapes (when reshaping box) and have the other move also, keeping the same separation of n pixels.
    If I simply scale the shape objects when parented then the width of the stroke obviously changes which isn’t desirable.
    I tried something like:
    ON THE SHAPE LAYER PATH TO BE THE CHILD –
    base=thisComp.layer(“BASE”).content(“Shape 1”).content(“Path 1”).path;
    [base[0],base[1]]-[3,-3]
    …but my understanding of the array coding mathematically is wrong.
    Any guidance would be good. Thanks
    Brian Charles replied 12 years, 5 months ago 4 Members · 3 Replies
  • Dan Ebberts
    April 10, 2014 at 6:45 am
    I don’t think there’s any way to do math on a path shape. I think valueAtTime() is the only tool in the toolbox, and I don’t think it helps for your situation.
    Dan
  • George Goodman
    April 10, 2014 at 1:12 pm
    I’m sure Dan is right about the expression. But what if you precomposed it, duplicated it, scaled one down, and then generated a stroke on the smaller precomp so that it matched the sizing of the other? Might not be perfect, but could potentially work.
    “|_ (°_0) _|”
    Sincerely,
    George
  • Brian Charles
    April 10, 2014 at 6:00 pm
    I’ve linked 2 shape layers with a couple of sliders and a simple expression here, this may work for you.
    Here’s a CS6 version of the file:
    7356_shapelinked.aep.zip
    ….And another version with the shapes in a single layer grouped.
    7357_boxshapegroup.aep.zip
