Activity Forums Adobe After Effects Expressions Expression to drive wiggle by velocity?
  • Expression to drive wiggle by velocity?
    Posted by Joel Witmer on May 21, 2010 at 8:02 pm
    Can anyone please explain how I can set the wiggle amount and frequency so that it is driven by the velocity of the camera movement? So the faster the camera moves over time, the more camera wiggle there would be and vica versa.
    I’m new to expressions so while I have an idea of what I need to do I can’t seem to figure it out exactly.
    Joel Witmer replied 16 years, 3 months ago 2 Members · 2 Replies
  • Darby Edelen
    May 21, 2010 at 10:24 pm
    You can access the velocity of the camera’s position with:
    thisComp.activeCamera.transform.position.velocity
    or if applied directly to the camera:
    or if applied directly to the camera’s position:
    velocity
    Note that a velocity is a vector, so you will be receiving an array with 3 components (x, y and z). My guess is what you’d rather do is find the speed at which your camera is moving, which is a scalar that corresponds to the magnitude of the velocity. For speed use:
    thisComp.activeCamera.transform.position.speed
    speed
    Once you have the speed, you can alter the value in order to end up with the frequency and amplitude of your wiggle. If applied to your camera’s position property:
    f = linear(speed, 0, 3000, 0, 5); //as the camera's speed changes from 0 to 3000 pixels per second, increase the frequency from 0 wiggles per second to 5
    a = linear(speed, 0, 3000, 0, 50); //as the camera's speed changes from 0 to 3000 pixels per second, increase the amplitude of the wiggle from 0 to 50 pixels
    wiggle(f,a); //apply the wiggle
    This code isn’t perfect, as wiggle will change it’s results proportionally faster with the rate of change of the frequency, so you’ll actually get more shake during periods of acceleration than during periods of high speed (where there will also be a good amount of shake, but not as much as during acceleration/deceleration).
    Darby Edelen
  • Joel Witmer
    May 24, 2010 at 5:37 pm
    Thanks so much Darby!
