Activity Forums Adobe After Effects Expressions expression to cull back-facing 3d layers
  • expression to cull back-facing 3d layers
    Posted by Kerovisuals on October 12, 2005 at 8:59 am
    Im sure this is fairly simple, but my knowledge of expressions is very limited. I have a 3d layer that orbits around a 2D globe and need it to be hidden when it appears “behind” the globe (technically it isnt behind, as the globe has no z-depth). i cant make the globe layer 3d, so is there an expression i can add to hide (either through opacity or visiblity) the orbiting layer when it is turned away from the camera? i believe the equivelant in 3D packages is called “cull back-facing planes”.
    Dan Ebberts replied 12 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Mylenium
    October 12, 2005 at 9:47 am
    This is some code from Dan Ebberts that should do the trick:
    a = toWorldVec([0,0,1]);
    b = thisComp.layer(“Camera 1”).position – toWorld(anchor_point);
    c = dot(a,b)/length(b);
    if (c > 0) 0 else 100
    Apply it to the opacity parameter.
    Mylenium
    [Pour Myl
  • Kerovisuals
    October 12, 2005 at 10:26 am
    thanks mylenium – works like a charm.
    and thanks to dan as well – discovering his motionscript site has just opened up a world of learning to me!
  • Dan Ebberts
    October 12, 2005 at 10:51 am
    Hey guys, for future reference, this one does the same thing more efficiently:
    if (toCompVec([0, 0, 1])[2] > 0 ) value else 0
    Dan
  • Sam Hamann
    December 31, 2013 at 7:46 pm
    Here’s a question. Is there an expression that would allow me to have video on the “front” side of a layer and the have it fill the “back” with white? So, when it flips over, it turns white?
  • Dan Ebberts
    December 31, 2013 at 8:31 pm
    You could try adding a Color Overlay Layer Style (set to White) and add this to its Opacity parameter:
    if (toCompVec([0, 0, 1])[2] > 0 ) 0 else 100
    Dan
  • Sam Hamann
    December 31, 2013 at 9:31 pm
    That’s awesome! Thank you so much.
    Do you mind telling me what the expression is telling the opacity to do so I can understand a bit better? I realize it’s New Year’s Eve and you probably have 150 other, more important things to do.
  • Dan Ebberts
    December 31, 2013 at 9:43 pm
    It’s really just a slight variation of this one:
    https://www.motionscript.com/design-guide/invisible-facing-away.html
    Dan
