Expression to Create Arcs in After Effects
Hi, is there a technique that lets us attach start and end points to a Null object (like the popular Beam effect technique) but with a curve?
Preferable a technique/script that does not need a plug-in since I’m going to export a mogrt file to pass to video editors.EDIT: I tested AE 2018 and Create Nulls from Paths worked great, but I need something that’s compatible with AE 2017 unfortunately
Like this:
If found the gif here:
https://motionographer.com/2017/10/25/everything-is-awesome-until-it-isnt/
