Activity › Forums › Adobe After Effects Expressions › Expression to count up every X amount of frames
  • Expression to count up every X amount of frames
    Posted by Aoife Mccarthy on June 18, 2020 at 5:32 pm
    Hi all!
    I’m currently working on an animated data visualisation, and I’m having issues syncing up my animated timeline with my data points on the chart. The timeline looks like this:
    The marker moves along the timeline from left to right, whilst the day marker to the right counts up.
    In the expression for the data points, each day has a duration of 3 frames. So 0:00:00:00 = val1, 0:00:00:03 = val2, 0:00:00:06 = val3 etc.
    I’ve used a slider control for the day marker (setting start and end values to 1 and 29/30/31 respectively), with this expression in Source Text:
    Math.round(effect("Slider Control")("Slider"))
    However it doesn’t exactly sync up with the data – some days get 4 frames, some get 3 etc. Is it a rounding issue?
    I think I need to create some kind of integer counter that counts up every 3 frames exactly – can anybody help?
    Aoife Mccarthy replied 6 years, 3 months ago 3 Members · 5 Replies
  • Aoife Mccarthy
    June 18, 2020 at 8:24 pm
    If it helps, this is how I’ve managed to get it working with keyframes… there must be a way to automate this though!
  • Dan Ebberts
    June 18, 2020 at 9:39 pm
    I’m not clear on what you’re doing, but something like this might fit in there somewhere:
    Math.floor(effect(“Slider Control”)(“Slider”)/3)*3
    Dan
  • Aoife Mccarthy
    June 19, 2020 at 8:41 am
    Hi Dan, thanks for your suggestion. That’s not quite what I need though – I’ve just tried it out and it’s counting up in 3’s, I need it to increment by 1.
    Basically what I need is a counter that counts up from 1 – 30, with each number having an exact 3 keyframe duration. I think my issue with using a slider is I end up dealing with floating point precision, which makes the distribution of keyframes slightly uneven.
    I’ve achieved it manually by using toggle hold keyframes on the slider property, ie 0:00:00:00 → Slider = 1, 0:00:00:03 → Slider = 2, 0:00:00:03 → Slider = 3 etc.
    Does that make sense? Let me know if there’s any other salient points I’ve missed!
  • Robert Müller
    June 19, 2020 at 9:40 am
    Hi, this should do what you are looking for
    t=timeToFrames();
    frameStep=3;
    days=30;
    Math.floor(t/frameStep)%days+1
    this counts to 30 (or any number you put for “days”) every 3 frames (or any number you put for “frameStep”), starting at 1 and resetting back to 1 after 30.
    If you want to stop at 30 try this:
    t=timeToFrames();
    frameStep=3;
    f=Math.floor(t/frameStep)+1;
    if (f>30){30}else{f};
  • Aoife Mccarthy
    June 19, 2020 at 11:59 am
    Hi Robert – that’s it! Thanks a million
