Activity Forums Adobe After Effects Expressions Expression to change value of keyframe
  • Expression to change value of keyframe
    Posted by Noel Powell on June 4, 2012 at 2:20 pm
    Hi. I’m looking for a way to use a slider control to change a parameter value at a specific keyframe. Or, if I can do it without keyframes, just a way to use a slider control to change the value at a specific frame.
    Here is what I’m trying to do…
    I need a slider control to change the number of particles using CC Particle World or CC Particle Systems II. The catch is the particles need to be static, so no new particles are formed. The only way I’ve found to stop new particles from forming is to have two keyframes on the “Birth Rate”. The value at the first keyframe determines the number of particles, then on the next frame would be a keyframe with the value set to zero, stopping any new particles from forming. And then I would set the longevity to a high number so they don’t disappear.
    The other problem I will have to solve is having those particles visible immediately (starting at frame 1). This seems impossible to me though because the CC Particle Systems appears to need at least a few frames before any particles can be formed. And if I have an expression that points to a specific frame, and I slider the layer to the left so that the specific frame is before the 0:00 frame, then the time of that frame will have changed, screwing up the expression. I hope that makes sense. Thank you.
    Noel Powell replied 14 years, 3 months ago 2 Members · 3 Replies
  • Dan Ebberts
    June 5, 2012 at 2:46 pm
    I don’t know if this helps, but this Birth Rate expression should give you a burst of particles at each layer marker:
    burst = 10;
    n = 0;
    m = marker;
    if (m.numKeys > 0){
    n = m.nearestKey(time).index;
    if (m.key(n).time > time) n--;
    if (n > 0 && Math.abs((m.key(n).time - time)/thisComp.frameDuration) < .5)
    burst
    else
    0
    Dan
  • Dan Ebberts
    June 5, 2012 at 4:12 pm
    This version might be closer to what you’re after. It fires a burst of particles at each slider keyframe and gets the birth rate value from the slider at the keyframe.
    p = effect("Slider Control")("Slider");
    n = 0;
    if (p.numKeys > 0){
    n = p.nearestKey(time).index;
    if (p.key(n).time > time) n--;
    if (n > 0 && Math.abs((p.key(n).time - time)/thisComp.frameDuration) < .25)
    p.valueAtTime(p.key(n).time+.01)
    else
    0
    Dan
  • Noel Powell
    June 6, 2012 at 2:17 am
    This is a life-saver. I don’t fully understand it, but I’m just thrilled that it works. I couldn’t use the first expression which used markers because it didn’t allow the number of particles to be changed with the slider. The second one works great with one little addition. If the slider value was changed it would create new keyframes at that location, making the number of particles change. I needed the number to be constant, so I made that control slider a dummy slider with just one keyframe at the beginning, and created a new slider to control the number of particles. The dummy slider, which your birth rate expression still points to, now has this expression on it:
    expression (effect(“New Slider”)(“Slider”)
    Seems to do the trick. Thanks for your help, Dan
