Activity Forums Adobe After Effects Expressions Expression to change value of a keyframe (fix)
  • Expression to change value of a keyframe (fix)
    Posted by Alekos Mazzolotti on May 25, 2021 at 1:48 am
    Hi, friends! I’m trying to solve this puzzle here:
    Those keyframes control a slider that determines de x value of a rectangle size (since I can’t separate dimensions there).
    I figured this expression to make the value of the second keyframe always change to the size of a text layer, and it always worked like a charm, because the last two keyframes usually go back from text-size to zero.
    Except, this time, for a reason, I don’t need the last keyframe to be zero. I need its value to be exactly 165, but because of the proportion resulting from the linear expression, it turns to whatever proportional value. Is there a way to “continue” the expression and make the last keyframe end in 165, no matter what?
    Alekos Mazzolotti replied 5 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
