Activity Forums Adobe After Effects Expressions Expression to change source text on one layer to match another
  • Expression to change source text on one layer to match another
    Posted by Chris Huggett on July 12, 2005 at 8:54 am
    Hi there
    I have two text layers. Each say the same thing and each are directly ontop of each other. The top layers text changes quite often and i want the layer below to change with it using an expression
    I have set an expression for the bottom layers source text parameter and pickwhipped it to the above layers source text parameter, but the text then offset itself and didnt directly match up.
    Any idea on what i can do?
    Chris
    https://www.acclaim.tv
    Mylenium replied 21 years, 2 months ago 2 Members · 3 Replies
  • Mylenium
    July 12, 2005 at 11:15 am
    Just pickwhip the position parameter in addition to the source text. They are treated separately by AE.
    Mylenium
    [Pour Myl
  • Chris Huggett
    July 12, 2005 at 10:09 pm
    Hi Mylenium
    On my top layer, i have adjusted kerning and adjusted the baseline of some characters. THis is not reflected in the layer below. Do you have any idea how to copy this?
    Chris
  • Mylenium
    July 13, 2005 at 5:55 am
    Nope, you can’t. If use this adjustments, you have to copy & paste everything to the other layer. Some parameters can be adjusted with multiple layers selected, though, so give that a shot.
    Mylenium
    [Pour Myl
