Activity Forums Adobe After Effects Expressions Expression to calculate Color Blending Mode on 2 color values?
  • Expression to calculate Color Blending Mode on 2 color values?
    Posted by Jacek Skro on September 10, 2019 at 11:53 am
    Hi all,
    I try to make flickering light changes effects stack like this: https://vimeo.com/338472778
    I made it with help of precompositing, but now I try to recreate it as an single adjustment to more convenient use.
    So my question is: is there expression to calculate Color Blending Mode on 2 color values?
    To be more specific:
    I have sampled RGBvalue1 and RGBvalue2 and I want to make some expression on it to receive RGBresult as a result of LinearLight Blending Mode beetween the two, same as it would be in the following setup:
    – Solid1 layer with color RGBvalue1 (lower)
    – Solid2 layer with color RGBvalue2 (over previous one) with blending mode LinearLight (or any other standard blending mode to choose).
    I didn’t find any built-in command in AE’s expressions to blend (mix) color values. Or I missed someting?
    Or maybe some math on RGBvalue1 and RGBvalue2?
    I found a webpage where LinearLight is defined as:
    (Blend > 0.5) * (Target + 2*(Blend-0.5)) + (Blend <= 0.5) * (Target + 2*Blend - 1)
    But I struggle how convert it to AE’s JavaScript expression.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Oleg Pirogov replied 6 years, 10 months ago 2 Members · 1 Reply
  • Oleg Pirogov
    October 29, 2019 at 5:39 pm
    So you have two color vectors:
    [r2, g2, b2, a2] for the top solid (Solid2) corresponding to Blend (also called source)
    [r1, g1, b1, a1] for the bottom solid (Solid1) corresponding to Target (also called backdrop)
    The formula you’ve found simplifies to
    Target + 2*Blend – 1
    Linear Light is a separable blend mode, meaning that the formula is applied to each color channel separately.
    For instance, for the red channel it will be:
    r = r1 + 2*r2 - 1
    – same for g and b.
    If both the Blend and the Target colors have alphas a1=a2=1, then the resulting color is simply:
    [r, g, b, 1]
    If not, then it gets worse, cause alphas have to be taken into account.
    Let:
    C2 = [r2, g2, b2]
    C1 = [r1, g1, b1]
    B=[r, g, b]
    C – resulting RGB vector (without alpha component)
    a = a1+a2 – a1*a2 – resulting alpha
    Then:
    C = (1 – a2/a)*C1+(a2/a)*((1-a1)*C2+a1*B)
    And the resulting color vector will be:
    [Cr, Cg, Cb, a], where Cr, Cg, Cb are the components of C.
    JS code:
    color2 = thisComp.layer("Pre-comp 1").sampleImage([1800,100], radius = [.5, .5]);
    color1 = thisComp.layer("Pre-comp 1").sampleImage([100,800], radius = [.5, .5]);
    C2 = color2.slice(0,3);
    C1 = color1.slice(0,3);
    a2=color2[3];
    a1=color1[3];
    a=a2+a1-a2*a1;
    function linearLight(r1, r2){
    return r1 + 2*r2 - 1;
    B = [linearLight(C1[0], C2[0]), linearLight(C1[1], C2[1]), linearLight(C1[2], C2[2])];
    aC=(a - a2)*C1+(a2)*((1-a1)*C2+a1*B);
    z=[aC[0]/a, aC[1]/a, aC[2]/a, a];
    It appears that it gives the right result.
